Re: Super A Generator
Posted by Haas on October 24, 2004 at 02:57:52 from (12.65.6.118):
In Reply to: Super A Generator posted by Scott KY on October 23, 2004 at 15:21:12:
Others comments about grounding of relay and polarizing apply. I bet the generator is not charging because it needs to be polarized. Likely your A is positive ground and generator shops these days probably polarized it for negative ground. The A tractor charging system used a cutout relay mounted on top of the generator. If that is what you have, it is probably original. You can replace the cutout with a voltage regulator. Aftermarket regulators are available that mount on the generator just like the cutout relay. No one but you will likely notice that there is a regulator instead of the original cut out relay. The system will work better with the regulator and you don't have to worry about setting the charging rate with the switch.
Post a Followup
Subject:
