Re: small metal stamped tags
Posted by Bob on October 24, 2004 at 09:48:49 from (66.163.134.177):
In Reply to: small metal stamped tags posted by Kevin Brooks on October 24, 2004 at 09:40:30:
They indicate the casting's birthday, day, month, and year, with the year using the following code:
1938-H 1947-Q 1957-C
1939-I 1948-R 1958-D
1940-J 1949-S 1959-E
1941-K 1951-W 1960-F
1942-L 1952-X 1961-G
1943-M 1953-Y 1962-H
1944-N 1954-Z
1945-O 1955-A
1946-P 1956-B
I believe, upon closer inspection, you will find that they are not actual tags, but rather, are part of the actual casting. A tag was put on the original pattern, which was pressed into the sand mold for the cast iron casting, and the impression of the tag is reproduced on the actual casting.
Post a Followup
Subject:
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
