Re: small metal stamped tags
Posted by Bob on October 24, 2004 at 09:48:56 from (66.163.134.177):
In Reply to: small metal stamped tags posted by Kevin Brooks on October 24, 2004 at 09:40:30:
They indicate the casting's birthday, day, month, and year, with the year using the following code:
1938-H 1947-Q 1957-C
1939-I 1948-R 1958-D
1940-J 1949-S 1959-E
1941-K 1951-W 1960-F
1942-L 1952-X 1961-G
1943-M 1953-Y 1962-H
1944-N 1954-Z
1945-O 1955-A
1946-P 1956-B
I believe, upon closer inspection, you will find that they are not actual tags, but rather, are part of the actual casting. A tag was put on the original pattern, which was pressed into the sand mold for the cast iron casting, and the impression of the tag is reproduced on the actual casting.
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
