Farmall Tractors Discussion Board
Need input flywheel
Posted by Greg on November 17, 1999 at 11:03:54 from (169.207.114.71):
I bought Cub Lo-boy 154 that I thought had a bad clutch. Today I got around to taking a look at it and found out the clutch is ok. But the input flywheel (the piece of metal the pressure plate bolts to) is broken. One of the halves that the bolt goes through broke off. Does anyone have one off a salvage tractor? What would cause this to break - so when I put it back together I don't make the same mistake the last person did.
Thanks,
Greg
Post a Followup
: Re: Need input flywheel
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
