Re: distributor problems
Posted by MagMan on October 25, 2004 at 03:23:58 from (152.163.101.13):
In Reply to: Re: distributor problems posted by Just learning on October 25, 2004 at 01:46:23:
Depending on what you want as far as looks $100.00 up to $150.00.Dist being the lower end and mag at the higher.These are rebuilt units To spec not used. JON
Post a Followup
Subject:
