Re: IH 70 Plow reduce to 2 bottom?
Posted by Hugh MacKay on April 03, 2009 at 14:08:58 from (216.208.58.135):
In Reply to: Re: IH 70 Plow reduce to 2 bottom? posted by rustyfarmall on April 03, 2009 at 06:17:11:
Rusty: One problem, the front wheel rockshafts on a No. 70 plow go through 3 and 4 plow beams depending on the model. (minamum 3 beams) Then when you get that one solved the axle rockshafts on a No. 70 are set back on plow beams about 18" compared to a two bottom plow. Left axle rockshaft crosses directly over shin of second moldboard. Right axle rockshaft crosses directly over front bottom shin. Once you remove the two back bottoms and beams, the back wheel lifts and plow nosedives.
