Re: 656 Farmall Radiator
Posted by K.B.-826 on October 25, 2004 at 18:58:11 from (209.163.30.30):
In Reply to: Re: 656 Farmall Radiator posted by NDCurt on October 25, 2004 at 10:41:49:
Curt, you're probably seeing the power steering or hydraulic oil cooler lines, but they will have nothing to do with a leak. The best way to check is to remove the hood and side panels, warm up the engine, and start looking. It should jump right out at you. Don't forget about the drain cock in the bottom of the radiator, those can leak. Did you put new hose clamps on the lower hose when you replaced it? Sometimes it just dosen't work to reuse the old clamps. Other than that, you'll have to pull the radiator and have it leak tested, Really not too bad to remove.
Post a Followup
Subject:
