Re: farmall super c hydraulic repair kits
Posted by CNKS on October 25, 2004 at 19:19:59 from (207.178.96.212):
In Reply to: farmall super c hydraulic repair kits posted by arthur gauna on October 25, 2004 at 19:09:24:
The o-rings you can find about anywhere. The gaskets from Case-IH are about as cheap as anywhere. If you are going to overhaul the reservoir, the kit from Case-IH costs $90-$100. Too much? Maybe, but it includes all you need for the reservoir, except the boots. If all you want to work on is the pump, it won't cost much, unless you have to use a speedy sleeve on the shaft. You may find that your 49 shaft has a seal (leaks into the crankcase), and the 53 an o-ring. If so you can't put a speedy sleeve on the 53 unless you enlarge the shaft hole.
Post a Followup
Subject:
