504d rings
Posted by steve turner on October 26, 2004 at 13:57:53 from (139.60.210.5):
ok, i know it sound weird but i'm looking for some used piston rings and maybe pistons for a 504d. i have a 504 that has sat for many years and i dont know what else is bad until i get the engine running. if many more things are bad i'll give up at that point. if not then i'll buy an inframe kit and rebuild the engine right.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
