ihc 400 prestolite distributor timing
Posted by jim ball on October 26, 2004 at 17:41:20 from (63.122.72.35):
i took off my prestolite distributor to get pts, condesor, rotor & cap. i am not sure how to time it correctly. i set no 1 (front towards rad)at tdc (first mark). the distributor rotation is clockwise as viewed facing it. dwell set at .020 ". cover below rotor shows "interlock".
there is one notch in cap. is this where no 1 wire goes. firing order is 1-3-4-2. i put a plug wire lite check and it shows spark. what am i doing wrong.
Post a Followup
Subject:
