Farmall B Cracked frontend
Posted by Elmer on October 28, 2004 at 12:32:01 from (69.58.141.90):
When I took the radiator off my B for repair, I found that the whole front end of the tactor is cracked where it mounts to the block. It evidently had been welded before but didn't hold. Can this be successfully repaired or do I have to replace? If replacement is needed, what are some good suppliers for this type of part? It looks now like a good bump in the road might knock the whole front right off the tractor.
Post a Followup
Subject:
