Re: finding a WD-40
Posted by Kevin Cooke on October 28, 2004 at 17:29:04 from (24.231.251.162):
In Reply to: Re: finding a WD-40 posted by Sloroll on October 25, 2004 at 19:06:44:
I have 4 WK 40 they will range $5000 up to $6000. The prices are that high because the engines are totally rebuilt with less that ten hours on them thats on the two that are painted the one that is original is a very nice one and there is a glider kit one that doesnt havr the original motor and is still in under construction. I have three diesels an early a middle and a late one. I know of two more for sale one in canada for 9500 one in ct for 14000 also an ID40 early model something mismatched about the numbers that supposedly runs on gas for about 6000
kevin
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
