Re: which one would you get?
Posted by matthew h on October 28, 2004 at 18:33:53 from (68.119.48.224):
In Reply to: Re: which one would you get? posted by ericlb on October 28, 2004 at 16:30:57:
ericlb, not trying to talk you into getting a cub, but don"t worry to much about it technically having less hp than your riding mower. I have one and an eighteen hp "garden tractor" with mower deck. The cub has has an IH belly mower. The cub is as fast if not faster and eats up much thicker stuff without grumbling and much easier on the operator when you dealing with something rougher than the front lawn.
I think it has as much to do with the equipment"s ability to get that horsepower to the ground/grass as it does engine horsepower. On the cub, I don"t have to worry about belts slipping (although the belly mower is belt drive), deck getting clogged up, or getting stuck in the least litte hole. The cub is also designed to operate at near maximum hp all day long. Try that with most of these air cooled engines and it won"t be with you long.
But make no mistake about it, a cub is a small tractor with limits and an A, B, 100, 130, 140 is much more tractor.
I"ll give you one more option since you stayed with me this long. I have seen belly mowers for the little Fords like the NAA, I think made by Woods. I think that would be a great setup for medium sized jobs.
good luck
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
