Re: 560D head repair
Posted by captaink on October 29, 2004 at 08:03:44 from (66.115.214.56):
In Reply to: 560D head repair posted by SamC.VT on October 29, 2004 at 06:31:28:
This is from personal experience. When you get the head off, check the depth of the valve heads compared to the deck of the head. If they are not within spec, get the seats replaced and so they are back into spec. This will improve cold starting. The gasket mating surfaces of the block and head should be flat. I worked on a 460 once that was notorious for leaking water to the outside and I found a depression about the size of a nickel in the deck of the block. I decided to try JB weld (it had just come out) to fill it and it solved the problem. Depending on how it was starting and running before, you might want to consider having the injectors and injector pump checked. Were you loosing any water? If so, in addition to the head you will want to check the sleeves, etc. Oil consumption and blow-by should be considered as if either is excessive; you might want to do a complete rebuild if you use the tractor enough. Just some thoughts. I bought one about 22 years ago that wouldn’t start below +40 F without an M and a log chain in front. After I rebuilt and fixed valve seats, valve guides, put in new sleeves & pistons, worked injectors and pump, etc. The engine was back to spec and would start to at least -10 F without being plugged in. Found out the hard way one day when the block heater failed and it still started! Gotta love them when they do that! :>)
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
