Re: IH 3414 B414 Injection Pump timing
Posted by JB2 on October 31, 2004 at 06:13:20 from (24.157.143.220):
In Reply to: Re: IH 3414 B414 Injection Pump timing posted by Franklin Scott on October 30, 2004 at 20:57:11:
Hi, the timing cover that has to be removed is on the front side on the rad side then you take the nut off and drive the shaft out of the timing gear.
My memory maybe incorrect, I could be confused with Bosch pump from 454. It could have a three bolt flange coupling to the injector pump but it would only fit in the proper place.
Is your lift pump working properly. It should squirt fuel a couple feet at the inlet pipe to the injector pump.
Good luck
JB
Post a Followup
Subject:
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
