Re: installing clutch on a M Farmall
Posted by Aces on October 31, 2004 at 10:20:56 from (65.54.98.27):
In Reply to: installing clutch on a M Farmall posted by TAH on October 30, 2004 at 12:10:07:
TAH never knew there to be but one of those drive plates should only need one. The screws are tapped just behind the threads so they tighten into the ears on the clutch and the tranny coupler ears. If the thick plate is to thick the screws will not tighten into the ears at the tapper and if the thin one is to thin the rubber washers will not tighten up. As for the plate lay it on a flat surface either side up, the two corners down need to bolt to the tranny and the two corners up need to bolt to the clutch shaft. If you go the other way the whole thing will be to short and the clutch shaft will not set in the pilst bearing in the flywheel.
Post a Followup
Subject:
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
