Re: IH 3414 B414 Injection Pump timing
Posted by Franklin Scott on October 31, 2004 at 16:58:16 from (209.107.194.96):
In Reply to: IH 3414 B414 Injection Pump timing posted by Franklin Scott on October 30, 2004 at 20:13:02:
Well, I finally got her running this afternoon...I think the timing is off still, as when I brought number 1 piston up to TDC the timing gear for the injection pump and the idler gears marks were 3 teeth off...Not sure if this is the way it should be but book says they supposed to be dead center...Reason I think it's still off is when you start it, it smokes black a good bit, then no smoke when running at idle..almost hard to tell it's running...I may be able to fine tune by twisting the pump a little bit...The pump is held onto the gear by 3 bolts, so it ain't yo yo proof as I found this one to be off 1/3 rd turn.....
Post a Followup
Subject:
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
