Re: W-4 won't start
Posted by EricB on November 01, 2004 at 07:05:01 from (216.209.84.11):
In Reply to: W-4 won't start posted by w4 on November 01, 2004 at 04:46:30:
As Rusty says, check the points. When you have those points closed its a good time to turn on the ignition and flick them apart. You should see a spark. If not your electrical problem is before that point. I have had a number of weak coils as well. This can be very frustrating.
By removing a high tension wire you can hold it close to a ground source as a friend turns over the engine. You should see a spark to ground as the engine turns over. (I usually get the friend to hold the wire and I turn it over, but you can lose friends that way)
Post a Followup
Subject:
