Re: Can I make an axel tube for IH WF?
Posted by 26Red on November 01, 2004 at 09:13:01 from (170.92.100.2):
In Reply to: Can I make an axel tube for IH WF? posted by MM_TX on October 31, 2004 at 19:08:25:
You could make the center axle tube yourself. Keep in mind it has a lot of holes to put in it, and it should be free of weld flash on the inner diameter(so you can slide the spindle "knees" into ieach end. The center pivot is nothing special, just some round tubing welded in with bronze bushings pressed into it.
If you like make stuff, go for it, other wise I would just buy the new center tube. (Been there done that!)
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
