Farmall Tractors Discussion Board
Re: Ok...got the brake cover off and here is what I found -
Posted by JLE on November 18, 1999 at 05:13:10 from (12.76.65.106):
In Reply to: Ok...got the brake cover off and here is what I found - posted by Farmall Newbie on November 17, 1999 at 19:12:18:
Boy, are you bringing back memories, When the "M" was one of the biggest tractors in the country and done all the heavy work, plowing ect. It seemed like every yeear we would have two or three "M"s that would start leaking usually it was the land wheel and nine times out of ten it would mean that the bearing, behind the seal had gone bad.
After all this chatter what I'm trying to say is be sure and check the bearing while you are there. Jim
(Southwest Mich.)
Post a Followup
: Re: Re: Ok...got the brake cover off and here is what I found -
