Re: Oil coming from muffler
Posted by Michael Soldan on November 01, 2004 at 22:26:21 from (66.203.172.221):
In Reply to: Oil coming from muffler posted by Kyle from Kentucky on November 01, 2004 at 21:04:25:
You are getting condensed oil known as blow-by building up in your muffler. You will see it more in cold weather and running your tractor for short periods of time. If you worked the tractor hard all afternoon it would all burn off. You may have rings sticking, try a can of Risolone in the oil or even a quart of automatic transmission fluid into the oil, both of these will loosen sticking rings and valves. Give the tractor a good work out, avoid letting it sit idling. What you are getting is not uncommon. I have a Case 300 that will buid up oil in the muffler if it doesn't get a good workout once in a while...Mike in Exeter Ontario
Post a Followup
Subject:
