Do you by chance mean that it starts but as soon as you let off of start button it dies?
Does the tractor have a resistor in the coil circuit with a wire from coil end to start solenoid? (12 Volt coil "External Resistor Required")
If so your resistor is probably open. The resistor reduces 12 Volts to 6 Volts at coil. When start solenoid is activated it applies 12 volts to coil for hotter starting spark. When you start it goes on 12 volts, but let off starter and defective resistor is not supplying run current to the coil.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
