Re: Wrappin' It Up
Posted by captaink on November 02, 2004 at 07:22:31 from (66.115.214.56):
In Reply to: Re: Wrappin' It Up posted by Allan in NE on October 30, 2004 at 08:10:39:
third party image
Allen,
Remember the quick connectors on my M to go back and forth from the loader tank to the on-board tank on the tractor? Their may be a problem with plumbing it into your belly pump for a reservoir. The belly pump may not be large enough on it’s own to hold enough oil for the loader. If that turns out to be true, then you will need to go back to the tank on the loader but if you couple the two together, the fluid levels in the two will try to equalize. This may cause the supply tank on the H to overflow.
Just trying to prevent your having a mess someday…
Post a Followup
Subject:
