Re: Puzzling cooling problem on BN
Posted by Red Dave on November 03, 2004 at 05:02:09 from (24.104.94.34):
In Reply to: Re: Puzzling cooling problem on BN posted by ffolkes on November 03, 2004 at 04:26:22:
At the bottom of the water chamber around the sleeves there are 4 holes that allow water to travel up from the lower water inlet. I think these are the nickle sized holes gene b is refering to. If they are blocked, coolant will not flow up past the sleeves into the head then into the top of the radiator.
On my B I had to take the head off and poke a screwdriver down through the water passages beside the cylinders to unblock the holes. I flushed 2 handfuls of rust and scale out of my block that way.
Post a Followup
Subject:
