Farmall Tractors Discussion Board
Re: Ertl Die Cast Toys !!!
Posted by kendall steed on November 18, 1999 at 13:36:59 from (207.136.51.138):
In Reply to: Ertl Die Cast Toys !!! posted by bronco on November 17, 1999 at 17:46:17:
I have bough Ertl Farmall 1/16 from www.dstratton.com. They have a catalog of hundreds of Ertl everything. Another great place for Farmall 1/16 Ertl is www.ebay.com. You better be at you computer just as bidding closes because thats when the bidding gets hot. You might not get a screaming deal at ebay but you might find a tractor that's not in anyones catalog.
Post a Followup
: Re: Re: Ertl Die Cast Toys !!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
