Re: OK, now I am starting to get confused......nee
Posted by Michael Soldan on November 04, 2004 at 06:33:33 from (66.203.172.221):
In Reply to: OK, now I am starting to get confused......need he posted by Brian in NY on November 04, 2004 at 06:07:26:
Brian, have you access to an oxy-acetylene torch? Jobs like that broken set screw can be done by using the brazing tip and heating the area around the set screw red hot , then dousing with cold water, this breaks the rust and the screw should turn out...not withstandind that it is broken off, if there is enough of the screw left to get a hold of with a needle nose it should turn out. Some penetrating oil will really work now that the rust is broken. If there is not enough screw to get a bite on a very fine picking chisel just might turn the screw in its hole until you can grab on. Failing all this, you're back to easy outs. If you have to drill and use these extractors, the key is to centre punch the screw before you starts to drill, the more centered the hole the better the easy out will work. I would still heat and cool if I was doing it this way. I just did one of these set screws on the fan belt on one of my H's. I was lucky that the screw was in tact, but it was so siezed in that it wouldn't budge..turns in and out nicely now..I'm a "hot wrench" fan,heat it red, douse it with lots of water and you can take anything apart..good luck...Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
