Re: 12 volts coil
Posted by Doug in OR on November 04, 2004 at 08:58:19 from (159.121.94.198):
In Reply to: 12 volts coil posted by Luc Perron on November 04, 2004 at 06:20:03:
Some "12 volt" coils require a ballast resistor, some do not. Measure across the two terminals with an ohmmeter. If it reads about 1.5 ohms, you will need a ballast resistor. If it reads about 3.2 ohms, you can run it stock with no ballast resistor - the resistor will be in the coil. Be sure the coil is disconnected when you make this measurement. Any MOPAR ballast resistor will work, if needed. A weak yellow spark usually indicates other problems. Are your points good? Do you have a solid ground connection to your points? (No rust or grease or anything). Are all your connections between the coil and the ignition switch good and solid? A leaky condensor could cause this too. Your coil could be bad, but I would check all other connections first.
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
