Re: OK, now I am starting to get confused......nee
Posted by Andy Martin on November 04, 2004 at 11:25:34 from (64.219.39.195):
In Reply to: Re: OK, now I am starting to get confused......nee posted by Hayfarmer on November 04, 2004 at 07:10:09:
I didn't think they made pressure caps for the non-pressure radiators. The neck is not designed for the seal.
A reminder, non-pressure H and M still had a water pump, so you may just have an old radiator or old engine. It still should work fine. Have you checked the engine serial number and date code?
To add to what was said before, if the water level is above the core when cold, it has enough water.
Post a Followup
Subject:
