Re: H Farmall SN# 30,346 x1 strange front end
Posted by scotc on November 04, 2004 at 19:06:37 from (162.39.3.139):
In Reply to: H Farmall SN# 30,346 x1 strange front end posted by Loyd in Texas on November 04, 2004 at 18:56:52:
sounds like someone replaced the front casting with one from a 300 or 350, our 300 has one from an H because it appears someone used a hammer to try to break the crank pin loose and cracked the casting.
Post a Followup
Subject:
