Re: Drain your compressor!
Posted by CNKS on November 05, 2004 at 18:27:43 from (207.178.96.213):
In Reply to: Drain your compressor! posted by Nebraska Cowman on November 05, 2004 at 17:21:29:
I drain mine each time I use it -- because I use it for painting, and water and paint don't mix too well. I have a heated building, but the heat is off at night to keep me from going broke buying gas. Anything critical that might freeze, I set a light bulb beside.
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
