Re: Drain your compressor!
Posted by Ron in Nebr on November 06, 2004 at 07:56:29 from (65.169.97.35):
In Reply to: Drain your compressor! posted by Nebraska Cowman on November 05, 2004 at 17:21:29:
I used to work in a tire shop in a very old building in Chadron NE and we had two huge ancient compressors. It was standard practice to shut them off and drain them every single night. Probably that was part of the reason why they lasted so long.
Here at home though, I'm also guilty of forgetting to regularly drain our compressor. Good thing it's in a heated shop!
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
