Re: Changing Belts on a cub?
Posted by Haas on November 06, 2004 at 17:46:20 from (12.65.228.16):
In Reply to: Changing Belts on a cub? posted by Scott Stephenson on November 06, 2004 at 13:09:14:
The others don't say, but be sure when you loosen the fan spindle, you use a wrench on the hex on the front side of the bracket. That's the hex between the bracket and the fan. The nut is on the back side and is in a slot to keep it from turning when you put a wrench on the hex on the front side. I've seen folks try to get a wrench on the nut on the back side and you won't have any luck with that and just make a mess.
Post a Followup
Subject:
