Re: Farmall M engine swap to Chevy V 8
Posted by r4etired on November 06, 2004 at 18:50:10 from (152.163.101.13):
In Reply to: Farmall M engine swap to Chevy V 8 posted by Donald Burgett on November 05, 2004 at 04:54:45:
Donald' 2 winters ago I put a 345 IH V8 in a 560. It had been in a 915 combine, The combine application is simpler because you have a good solid front motor mount and you have a govenor already mounted and a carb set up for it.Getting the steering hooked back up like it was requires a couple extra U joints, Also the gas tank has to be shortened. Last winter I put a 345 IH V8 out of a 4wd pickup in my M.The chevy would better it's a lot shorter than the 345. When I looked into the chevy swap I couldn't find room for the starter. I do not alter the length or width of the frames. If you use a 345 the rear of the block takes a lot of alteration to get it set in. I used a spacer adapter and used the M clutch and starter. I had to use an electric fuel pump, no room for the cam driven one, Also an electric fan as the 345 is 21/2in longer than the 4 cyl. On the M I got a govenor from a MF 750 combine that had a 327 chev in it. Don,t know anything about chev performance spec.s but the 345 is 150hp @3200rpm max torque @ 2000 rpm At 2000 rpm it's 118 hp. I run both of mine at 1950rpm.I set the govenor to activate at a .5%drop Ground speeds are about the same.Plenty of power to pull a 4 bottom plow easy in about any gear. The 345 will burn about 9 gal of gas an hourunder load. My advice is take your time . alignment and balance are very critical
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
