Re: Farmall 100 Engine Rebuild Questions
Posted by stroker88 on November 09, 2004 at 19:21:17 from (64.215.21.130):
In Reply to: Farmall 100 Engine Rebuild Questions posted by Hobo,NC on November 09, 2004 at 18:14:37:
they are the same engine.#1 they are wet sleeves(one of very few ih).#2 will have to check on the crank specs.#3the shafts will inter change.#4the rods should be the same have seen some that are a bit beefier than others keep the weights as close as possible.if in good shape use the conformatics or domed pistons.#5 heads should be the same also. cam specs may differ i think they gave the 140 a few more rpm's. hope this helped, good luck.
Post a Followup
Subject:
