Re: Super A: Same old problem; NO Power!!
Posted by Ron in Nebr on November 09, 2004 at 22:54:32 from (65.172.143.15):
In Reply to: Super A: Same old problem; NO Power!! posted by PaulG on November 08, 2004 at 06:30:21:
Some other things to check, in addition to what's already been mentioned: what kind of inline fuel filter do you have? I recall reading somewhere that if it's just a standard one from a parts store, it's made to have pressurized fuel flow through it from a fuel pump and won't flow enough with just a gravity feed like your tractor has. Get an inline filter that's designed for a gravity flow system, such as one on a small engine application like a lawn tractor for example, and it will work much better.
Also, when you disconnect the fuel line from the carb, there needs to be a "full-pipe" steam of fuel coming out of it when the gas is turned on. If it just trickles out, it's not enough fuel.
One other thing that I've found that can cause the problem you describe is if the point gap is not set properly, so maybe recheck that too.
Post a Followup
Subject:
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
