Re: M vs.8n ford
Posted by Andy Martin on November 10, 2004 at 13:15:53 from (64.219.39.195):
In Reply to: Re: M vs.8n ford posted by Allan in NE on November 10, 2004 at 12:36:39:
Allan:
I just don't understand your response. Where I live, a typical 8N will bring $1,000 more than an M. That is why I have so many M's. They are too much of a bargain.
So, if both tractors are in average shape, it looks like the guy is offering a fair deal. If I had an 8N, I would trade straight across to get an M, but I would take the boot as well. Just because I disagree with market economics is no reason to ignore them.
Carlton:
It sounds like a fair deal, but always buyer beware. The seller may just want a three point but doesn't have the gumption to install one himself. I have no use for a three point, but the add on three points work well, and with the right valve setup, you will get up and down pressure.
I disagree that wide fronts turn over easier. They are a little softer ride but not much. I far prefer narrow front for both easy steering and clearance. You can go lots of tight places with a narrow front you can't get with a wide front both because you can turn sharper and don't have that wheel sticking out to interfere. Baling square bales, avoiding the previous round's bales at corners is a snap with a narrow front. With a wide front, you either abandon part of the windrow or stop, get off, move a bale, and get back on.
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
