Re: 460 farmall will not start ....NEED LOTS OF HELP!!!
Posted by El Toro on April 03, 2009 at 16:45:57 from (64.12.116.73):
In Reply to: Re: 460 farmall will not start ....NEED LOTS OF HELP!!! posted by ky's861 on April 03, 2009 at 16:12:25:
You should buy a 12 volt coil from Napa that has the builtin resistor p/n IC14SB. Cost is about $18.00. Remove the existing resistor. Hal
