Re: Help with my Super M overhaul
Posted by Hayfarmer on November 10, 2004 at 20:42:10 from (66.243.235.86):
In Reply to: Help with my Super M overhaul posted by Tim Malin on November 10, 2004 at 19:48:52:
Super M would have come with 4" flat tops, if you change sleeves and pistons in Super M block you can go to 4 1/8 inch bore. Not sure what you mean, new sleeves vs total overhaul. Total overhaul to me would be sleeve and piston kit, new rod, man and cm bearings, new gaskets everywhere, valve job also. I don"t think I would go with used pistons and new sleeves. If sleeves are worn out and they are steel would thing that pistons would wear more being aluminum.
Post a Followup
Subject:
