Re: Farmall 100 Engine Rebuild Questions
Posted by Stan(VA). on November 11, 2004 at 05:21:40 from (208.59.157.47):
In Reply to: Re: Farmall 100 Engine Rebuild Questions posted by Hobo,NC on November 11, 2004 at 04:59:09:
Most places also offer a .002 bearing. If you have any trouble with the 100 pulley, you might consider opening it up to the same ID as the 140 pulley, then drill and tap to install a set screw to hold it. Some early A & B's had a set screw and locking nut on their front pulleys. Just a thought.
Stan(VA).
PS - Might also want to use the 140 front cover since it has the timing indicator. Just transfer the timing marks from the 140 to the 100 pulley and check for clearance at the timing indicator on the 100 pulley OD.
Post a Followup
Subject:
