Farmall Tractors Discussion Board
Re: Hydraulic for Super C loader
Posted by Stan(VA). on November 19, 1999 at 04:54:33 from (207.79.164.6):
In Reply to: Hydraulic for Super C loader posted by T'other Fred on November 18, 1999 at 21:36:06:
You can either tap into the high pressure line in the manifold and run it to an aftermarket vale then return to where you cut the line (ie: in series). Or call a salvage yard and buy the factory remote valve system from a Super C or 200. They were used with the loaders, fast hitches or could be just ordered seperate to operate a remote cylinder. You remove the manifold from the pump to the touch control, and replace it with a valve that bolts to the touch control and a new manifold that attaches the valve to the pump. Also need the handle (mounts on the headlight bar) and connecting rod to the valve.
If you want to go aftermarket and stay out of the current system, buy a PTO pump from somewhere like Northern Hydraulics (I think they are now Northern Tool). It would be a higher volume pump (probably lift the loader faster), but would not be live (no pressure when the clutch pedal is down).
Stan(VA).
Post a Followup
: Re: Re: Hydraulic for Super C loader
