Re: 460 farmall will not start ....NEED LOTS OF HELP!!!
Posted by Janicholson on April 03, 2009 at 16:59:34 from (66.173.50.26):
In Reply to: Re: 460 farmall will not start ....NEED LOTS OF HELP!!! posted by El Toro on April 03, 2009 at 16:35:55:
If it is hooked into the distributor, and the points are closed, it should read in the 6 to 8 volt area. But if the points are open, or it is disconnected from the wire, it will read pretty close to the same on both ends. A bad resistor will heat and open up in the short time it is "running" but I would think it would show a no spark when static tested as well. I would just bypass it for a trial to see if it is the cause. Just thinking out loud. JimN
