Re: smoke from oil fill stack
Posted by gusc on November 12, 2004 at 22:19:49 from (63.97.117.55):
In Reply to: smoke from oil fill stack posted by mwkellner on November 10, 2004 at 13:49:47:
As rustyfarm says, you have blowby past the rings into the crankcase. This can mean worn rings or just too much load on the engine. (Lugging)
The metal mesh in the filler cap is to filter incoming fresh air to clear out all blowby fumes from the crankcase. You can have either a tube directly to the outside or a tube back to the engine air intake, either one is supposed to remove the blowby fumes from the crankcase.
Smoke is not supposed to ever come out this tube!
Post a Followup
Subject:
