Re: idle adjustment on M
Posted by ChadS on November 13, 2004 at 06:56:18 from (66.228.96.184):
In Reply to: idle adjustment on M posted by Carlton on November 11, 2004 at 21:00:31:
Carlton, to adjust the idle, you have to have the idle rpm set screw adjusted low enough to activate the idle circuit. The idle circuit is based off of throttle postion on the throttle shaft. At a certain throttle position, there is a machine slot in the throttle shaft, which then allows air to pass through the idle passages. there is several casting holes that have access to this air passage. Most of them are found when you remove the venturi from the throttle body, and you will see a few holes in there. I hope this helps explain the circuit a bit,, It does sound like the spring has lost its pull in the governor, check that out first,, ChadS
Post a Followup
Subject:
