Re: SuperMTA Motor Swap ??
Posted by Ross on November 13, 2004 at 08:18:18 from (63.77.205.138):
In Reply to: SuperMTA Motor Swap ?? posted by Todd L on November 12, 2004 at 17:58:06:
I'd think you might have to change the timing cover to put the later hydraulic pump on but I wouldn't swear to that. And of course you'd have less power but you probably won't miss it. As long as the block and heads are good, I don't see why you can't just bolt in the M motor and then later on redo the SMTA's origninal motor at your own pace.
Ross
Post a Followup
Subject:
