Re: Super A And A Super C Question
Posted by Hugh MacKay on November 17, 2004 at 02:36:13 from (216.208.58.118):
In Reply to: Super A And A Super C Question posted by terryj on November 17, 2004 at 00:16:42:
terry: The holes you mount implements on all those small Farmalls are coarse thread. On your dad's Super A, there was a change about half way through production so the serial number or year would help. My SA is a 53 and it has a round tapered shaft with woodruff keys in steering control arm and the cog. If yours is that type fixing those key and keyways will help. I understand A and older SA had a square tapered shaft. That change probably occured around 1951, when they changed tyrods to the automotive type. The other item you would need to acess is wear on the cog and worm. If worn those two are very expensive and hard to find a good one as well. I've heard prices all the way from $200. to $600. The bearings on the steering wheel shaft may need attention as well. If loose those should create end movement on that shaft. I have fixed three of these, all the tapered round shaft. One had worn worm and cog, it still has the worn worm and cog. Most of the play in steering comes right from those woodruff keys. We found keyways out of shape on the shaft as well. We ground larger keys to fit tight in shaft. Since the keyways had become flared, we welded along each edge of key welding it to the shaft. We then did some grinding on the weld. We had these so cog and steering control arm had to be pressed on. In two of the cases we got it right on, while the other needs a bit more work. We looked at this from a point of view that shaft was toast anyhow. New was very expensive. This was in 1992 and you could still buy new parts then, but not cheap. 12 years ago and 2 of them still tight as new. The 3rd one my 130 is the one with worn cog and worm, but it also has some movement in the keys as well. When I say we, my friend and I felt this was worth a try, we have been quite happy with it. Time was our biggest expence.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
