Farmall Tractors Discussion Board
Re: Hey, Farmer Bob - the results from the brake job....
Posted by GeezerMn on November 19, 1999 at 15:35:05 from (216.161.105.79):
In Reply to: Hey, Farmer Bob - the results from the brake job.... posted by Farmall Newbie on November 18, 1999 at 18:25:30:
Right side leaking? This side is the furrow wheel
when plowing and takes a heavy load.Check for
brg. failure by prying on brake drum with a bar
in various directions. The brg. can not be replaced from the outside on the M, super M yes.
You need to remove some heavy parts to replace
brgs.If your brake drum seal surface on hub is
groved-ringed seals will not hold.Dont mean to
paint dark picture for you Farmall Newbie--thats
the way old tractors are.
Post a Followup
: Re: Re: Hey, Farmer Bob - the results from the brake job....
