Re: burning out carbon on an IH 240?
Posted by captaink on November 18, 2004 at 11:27:18 from (66.115.214.56):
In Reply to: burning out carbon on an IH 240? posted by Dave D on November 18, 2004 at 10:50:27:
As a sanity check, first, does your temperature gauge work? If not, stop right there and fix it. I say this because you will need to keep an eye on it to make sure you don’t overheat the engine, possibly causing pistons and cylinder walls to score and the temper being taken out of the rings. Running an engine over 230 degrees F for extended periods can lead to boiling in the radiator, loss of coolant, and overheating the engine and ruining it. At the same time running the engine between 200 and 220 should help get rid of the carbon. Putting some kind of load on the engine will help too. I would also suggest that when you get ready to shut it down you open up the radiator and let it fast idle a few minutes to cool off. Second, I never, EVER, recommend placing anything directly against the front of the radiator when there is a shroud of any kind around the fan. I say this from a bad experience my uncle had doing this. The fan broke a blade off and it went through the top tank of the radiator! Looking back and learning from it I figure it was due to excessive pressures on the blades (because they were not able to move air through the radiator) that caused the fan blade to break. Could have been a freak thing, but I’m not taking the chance. Covering the front of the grill is another matter entirely. This allows air to still move through the radiator keeping the stress on the fan similar to an open front, but still changing the air flow to come from the warmer area near the engine. Usually this is sufficient to bring the engine up to operating temp. As one guy on this board so wisely said, posting questions here costs nothing, fixing something caused by lack of knowledge takes time and money, sometimes lots!
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
