Re: OT sort of.. truck carb problem
Posted by Redmud on November 18, 2004 at 11:49:58 from (216.167.146.82):
In Reply to: OT sort of.. truck carb problem posted by Kelly C on November 18, 2004 at 10:10:16:
Kelly, It could be the needle and seat like Allan said. But whatever you do check the power valve. also if you remove the top of the carb, make sure it has the helper spring on the shaft that runs through the end of the float. Lots of the springs get left out in a rebuild, and that type carb needs the helper spring.
Redmud:
Post a Followup
Subject:
