350 utility t.a.
Posted by Terry Gleason on November 18, 2004 at 19:37:28 from (4.224.153.120):
The t. a. on my 57 350 utility does not work. I have split the tractor and found that the t.a. clutch and pressure plate are rust frozen.I have removed them. Looking from the top, the planetary gears look good and the bearing and seals seem ok. Do I need to split the clutch housing from the transmission and check the t.a. unit from the other side? Will the replacement of the clutch assembly and bearing be enough? HELP
Post a Followup
Subject:
