Re: use teflon tape on a gas fuel line?
Posted by K.B.-826 on November 18, 2004 at 19:53:50 from (209.163.43.37):
In Reply to: use teflon tape on a gas fuel line? posted by Dave D on November 18, 2004 at 10:30:26:
Dave, there is no need for any type of thread sealer on the fuel line to the carb. The ends of the line are flared. The seal is made by the flared line sitting against the fitting. If it leaks, it means that the flare is cracked or the fitting is worn. Teflon tape is used with pipe thread, and it does stand up to gas and diesel fuel well, even though it does look dissolved when you take stuff back apart. There are a few places in that fuel system where pipe threads are used, but if you don't have any leaks right now, you should be fine.
Post a Followup
Subject:
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
